As I've learned it is not possible to re-use transitions in the new workflow editor. Is there at this point still an option to revert to the legacy editor in Jira Cloud? If so, how?
Hi @A_ Boehme
Has the change already happened to your side? When you go to edit a workflow do you have a Switch workflow option? If not, then the change already happened and you cannot revert it back.
@Nikola Perisic Phew, I found the option under the three-button menu at the top right when editing a workflow - I can still switch back. Thanks!
