Stop project deletion notifications
新井 聡 July 31, 2023
I get a notification every time I delete a project, can I stop it?
When testing in the sandbox environment, I create and delete multiple projects, and I want to stop the notifications from popping up every time I do so.
Benjamin
Hi @新井 聡 ,
Not sure if you can isolate it to just project deletion but you can disable outgoing e-mail for sandbox. ..this way all notification will be turn off. Usually, I do this, so in case of testing, team members don't accidentally get a large bulk of e-mails.
You may want to look into your personal settings for other notifications you may want to disable since you are on a sandbox.
新井 聡 August 20, 2023
Do I just set this to Disable?
