Sign up Log in
Story points
Dacota Li December 10, 2021
In Backlog there is no fiels "Estimation" in story points. Instaed of this there is field "Baseline estimate" in minutes. Please tell me how can I set the field "Estimation" in story points? Thank you
Trudy Claspill
December 10, 2021
Hello @Dacota Li
Welcome to the community.
Are you working with a Team Managed project or a Company Managed project?
Can you provide a screen image of what you see?
Dacota Li December 10, 2021 edited
Sure. It is in russian. I work with company manadged project Inkedback_LI.jpg
Trudy Claspill
December 10, 2021
Are you using a Scrum Board or a Kanban board?
Does Story Points appear in the section labeled Подробности ?
If you are using a Scrum board has estimation in Story Points been enabled?
  1. Go to Board Settings
  2. Select Estimation and see if  Estimation Statistic has been set to "Story Points"
Has the Story Points field been added to the Field Configuration used by this project and that issue type, and added to the Screen for that Issue Type?
Thanks. I did this. So now I can ser story point but for user story only. When I create a task or subtask there is "Baseline estimate" in minutes again. What is wrong?
Trudy Claspill
December 10, 2021
Story Points don't apply to Sub-tasks.
If you are using a default project configuration, it probably does not include having the Story Points field as part of the Tasks issue type. The Tasks issue type may be using a different field configuration and/or a different screen. Can you check those items?
Kristina
December 13, 2021
Thanks a lot for your answer. I've set this field. Thank you
FREE
Upcoming Jira Events
