String Function "substringBetween(String open, String close)" is returning unexpected values
Sam Sexson July 29, 2020 edited
I'm trying to parse a webhook response to remove some brackets by utilizing the "substringBetween()" function like this:
{{webhookResponse.body.schedules.schedule.onCallUser.username.substringBetween("[","]")}}
Without the substringBetween function, the value returned is "[user]"
When I check the audit log when using the function, it appears that it's _only_ capturing the brackets as shown here:
Am I using this function incorrectly?
Simmo
July 30, 2020
Hi @Sam Sexson ,
Could you provide an example of the web hook payload for me (remove anything thats PII or company related). Would make it a bit easier to see what is going on.
Simmo
Sam Sexson July 30, 2020 edited
Hi @Simmo , thank you for your time!  Of course!
"team": {
"name": "XXXXXXXXX",
"slug": "XXXXXXXXX"
"schedules": [
"policy": {
"slug": "XXXXXXXXX"
"schedule": [
"onCallUser": {
"username": "XXXXXXXXX"
"onCallType": "XXXXXXXXX",
"rotationName": "XXXXXXXXX",
"shiftName": "XXXXXXXXX",
"shiftRoll": "XXXXXXXXX",
"rolls": [
"start": "XXXXXXXXX",
"end": "XXXXXXXXX",
"onCallUser": {
"isRoll": true
"end": "XXXXXXXXX",
"onCallUser": {
"isRoll": true
"end": "XXXXXXXXX",
"onCallUser": {
"isRoll": true
"overrides": []
Simmo
August 2, 2020
Hey @Sam Sexson ,
Sorry about the delay in getting back to you. So, what I think is going on here is that schedule is an array/list.
So, webhookResponse.body.schedules and .schedule are both referring to a list. When that happens, we apply whatever comes next to all the list elements. In your case that is .onCallUser.username.substringBetween("[","]"). And then, because its a list we render it in list format which adds those square brackets.
If you try the following:
{{webhookResponse.body.schedules.first.schedule.first.onCallUser.username}}
 That might hopefully resolve your issue.
Simeon.
Sam Sexson August 3, 2020
@Simmo !  You are amazing!
Yes, that worked perfectly...  thank you so much for your time in getting me on track!  I appreciate the thorough explanation and recommended change!  Works perfectly!
Radzhiv Apasov August 18, 2023
@Simmo Hello, I hope this message finds you well. I'm writing to inquire about how to effectively use the substringBetween function in the given situation. I'm dealing with the following JSON structure:
"Type": "Notification",
"MessageId": "96d4c7c2-999e-57ab-aade",
"TopicArn": "arn:aws:sns:us-west-2:test",
"Message": {
"version": "0",
"id": "3ee38987-e0ce--91a1",
"detail-type": "EC2 Instance State-change Notification",
"source": "aws.ec2",
"account": "abc",
"time": "2017-09-11T10:49:41Z",
"region": "us-west-2",
"resources": ["arn:aws:ec2:us-west-2:asdf:instance/i-abc"],
"detail": {
"actionName": "custom-action-name",
"actionDescription": "description of the action",
"findings": [
"AwsAccountId": "abc",
"Compliance": { "Status": "PASSED" },
"Confidence": 42,
"CreatedAt": "2017-03-22T13:22:13.933Z",
"Criticality": 99,
"Description": "The version of openssl found on instance i-abcd1234 is known to contain a vulnerability.",
"FirstObservedAt": "2017-03-22T13:22:13.933Z",
"GeneratorId": "acme-vuln-9ab348",
"Id": "us-west-2/111111111111/98aebb2207407c87f51e89943f12b1ef",
"LastObservedAt": "2017-03-23T13:22:13.933Z",
"Malware": [
"Name": "Stringler",
"Type": "COIN_MINER",
"Path": "/usr/sbin/stringler",
"State": "OBSERVED"
"Network": {
"Direction": "IN",
"Protocol": "TCP",
"SourceIpV4": "1.2.3.4",
"SourceIpV6": "FE80:CD00:0000:0CDE:1257:0000:211E:729C",
"SourcePort": "42",
"SourceDomain": "here.com",
"SourceMac": "00:0d:83:b1:c0:8e",
"DestinationIpV4": "2.3.4.5",
"DestinationIpV6": "FE80:CD00:0000:0CDE:1257:0000:211E:729C",
"DestinationPort": "80",
"DestinationDomain": "there.com"
"Note": {
"Text": "Don't forget to check under the mat.",
"UpdatedBy": "jsmith",
"UpdatedAt": "2018-08-31T00:15:09Z"
"Process": {
"Name": "syslogd",
"Path": "/usr/sbin/syslogd",
"Pid": 12345,
"ParentPid": 56789,
"LaunchedAt": "2018-09-27T22:37:31Z",
"TerminatedAt": "2018-09-27T23:37:31Z"
"ProductArn": "arn:aws:securityhub:us-east-1:111111111111:product/111111111111/default",
"ProductFields": {
"generico/secure-pro/Count": "6",
"Service_Name": "cloudtrail.amazonaws.com",
"aws/inspector/AssessmentTemplateName": "My daily CVE assessment",
"aws/inspector/AssessmentTargetName": "My prod env",
"aws/inspector/RulesPackageName": "Common Vulnerabilities and Exposures"
"RecordState": "ACTIVE",
"RelatedFindings": [
{ "ProductArn": "arn:aws:securityhub:us-west-2::product/aws/guardduty", "Id": "123e4567-e89b-12d3-a456-426655440000" },
{ "ProductArn": "arn:aws:securityhub:us-west-2::product/aws/guardduty", "Id": "AcmeNerfHerder--x189dx7824" }
"Remediation": {
"Recommendation": {
"Text": "Run sudo yum update and cross your fingers and toes.",
"Url": "http://myfp.com/recommendations/dangerous_things_and_how_to_fix_them.html"
"Resources": [
"Type": "AwsEc2Instance",
"Id": "i-cafebabe",
"Partition": "aws",
"Region": "us-west-2",
"Tags": { "billingCode": "Lotus-1-2-3", "needsPatching": "true" },
"Details": {
"AwsEc2Instance": {
"Type": "i3.xlarge",
"ImageId": "ami-abcd1234",
"IpV4Addresses": ["54.194.252.215", "192.168.1.88"],
"IpV6Addresses": ["2001:db8:1234:1a2b::123"],
"KeyName": "my_keypair",
"IamInstanceProfileArn": "arn:aws:iam:::instance-profile/AdminRole",
"VpcId": "vpc-11112222",
"SubnetId": "subnet-56f5f633",
"LaunchedAt": "2018-05-08T16:46:19.000Z"
"SchemaVersion": "2018-10-08",
"Severity": { "Product": 8.3, "Normalized": 25 },
"SourceUrl": "string",
"ThreatIntelIndicators": [
"Type": "IPV4_ADDRESS",
"Value": "8.8.8.8",
"Category": "BACKDOOR",
"LastObservedAt": "2018-09-27T23:37:31Z",
"Source": "Threat Intel Weekly",
"SourceUrl": "http://threatintelweekly.org/backdoors/8888"
"Title": "title",
"Types": ["Software and Configuration Checks/Vulnerabilities/CVE"],
"UpdatedAt": "123578964332",
"UserDefinedFields": { "reviewedByCio": "true", "comeBackToLater": "Check this again on Monday" },
"VerificationState": "string",
"WorkflowState": "NEW"
"Timestamp": "2017-09-11T10:49:42.630Z",
"SignatureVersion": "1",
"Signature": "sign",
"SigningCertURL": "https://sns.us-west-2.amazonaws.com/SimpleNotification.pem",
"UnsubscribeURL": "https://sns.us-west-2.amazonaws.com/?Action=Unsubscribe&SubscriptionArn=arn:aws:sns:us-west-2:"
My goal is to extract information about findings' resources from the "Message" field and present it in a human-readable format. Specifically, I want to retrieve details from the "findings" array, specifically the "Resources" object within it.
I've attempted to use the substringBetween function in the following manner:
{{ Message.substringBetween("Resources:",",Id") }}
However, this approach didn't yield the desired outcome. I also tried using the regular expression extraction method:
{{ Message.extract(/"Resources":\s*\[(.*?)\]/) }}
I'm seeking guidance on the correct approach to achieve my goal of making the alert more human-readable and extracting information from the "Message" field's "findings" section. Any assistance or insights you can provide would be greatly appreciated.
Thank you in advance for your help and expertise.
Help us plant more trees
