Structure Formula - display colored value of a Variable
Uwe Döll June 23, 2022
i am calculating a value, that is saved in my variable "diff".
I want to show the value of the variable in structure with a colored background. I tried a lot, but instead of the value i only get the Name of my variable.
Here is a Part of my Formula:
with diff = X/Y:
IF diff < 0.5:
//$diff{backgroundColor=red color=white}
":panel[diff]{backgroundColor=red color=white}"
//FORMAT_CAPTION("RED", ":cloud_with_lightning_and_rain:" diff)
ELSE IF diff ...
In the picture you can see some Results. Instead of "diff" i want to se something like "1,54"...
The "Format_Caption" is a copy-paste from the helping sites - which did not help.
4 votes
David Niro
Hello @Uwe Döll ,
David from ALM Works here.  Welcome to the Community!
Your formula is 99% of the way there.  There are two adjustments we can make to get it working for you.
The first is to define diff as an expression using $ and to enclose the Text Snippet with """.
With those two modifications, your formula should look like this:
with diff = X/Y:
IF diff < 0.5:
""":panel[$diff]{backgroundColor=red color=white}"""
Please let me know if this helps!
Best Regards,
David
Good morning David,
Thanks for your help. It works exactly how i want it to :-)
Best Regards,
Uwe
Like 2 people like this
David Niro
You are very welcome, @Uwe Döll !  So glad to hear it was the right solution for you!
Best,
David
Like Dave Rosenlund _Trundl_ likes this
Stavros December 13, 2024
Thanks for the great answer, @David Niro
 It´s still helpful, fyi :)
Like Stepan Kholodov _Tempo_ likes this
