Sub Task Automation Custom Fields Blank
Andrew Vaughan July 22, 2021
Hey all,
I'm racking my brain and I've scoured the help here to no avail - I cannot determine how to get fields from a parent to a sub-task as part of automation.
I have an "On Issue Created" automation that I want to create a number of sub-tasks. This issue type I have limited for the automation has a number of custom fields associated with it.  As an example, one of these is "Employee Full Name".
I've tried *ALL* of the following to try to get that field as a variable into the sub-task generator, and all of them show up blank. What am I doing wrong??
# {{Employee Full Name}}
# {{Employee Full Name.value}}
# {{"Employee Full Name"}}
# {{"Employee Full Name".value}}
*fields.*
# {{fields.Employee Full Name}}
# {{fields.Employee Full Name.value}}
# {{fields."Employee Full Name"}}
# {{fields."Employee Full Name".value}}
*issue.*
# {{issue.Employee Full Name}}
# {{issue.Employee Full Name.value}}
# {{issue."Employee Full Name"}}
# {{issue."Employee Full Name".value}}
*issue.fields.*
# {{issue.fields.Employee Full Name}}
# {{issue.fields.Employee Full Name.value}}
# {{issue.fields."Employee Full Name"}}
# {{issue.fields."Employee Full Name".value}}
*issue.parent.*
# {{issue.parent.Employee Full Name}}
# {{issue.parent.Employee Full Name.value}}
# {{issue.parent."Employee Full Name"}}
# {{issue.parent."Employee Full Name".value}}
*issue.parent.fields.*
# {{issue.parent.fields.Employee Full Name}}
# {{issue.parent.fields.Employee Full Name.value}}
# {{issue.parent.fields."Employee Full Name"}}
# {{issue.parent.fields."Employee Full Name".value}}
*parent.*
# {{parent.Employee Full Name}}
# {{parent.Employee Full Name.value}}
# {{parent."Employee Full Name"}}
# {{parent."Employee Full Name".value}}
*parent.fields.*
# {{parent.fields.Employee Full Name}}
# {{parent.fields.Employee Full Name.value}}
# {{parent.fields."Employee Full Name"}}
# {{parent.fields."Employee Full Name".value}}
July 22, 2021
Hi @Andrew Vaughan
I am unclear about some of the extra characters in what you posted, and...
  • If you have a custom field named Employee Full Name which is available within an issue's scope...
  • Usually one of these will work:
    • {{issue.Employee Full Name}}
    • {{issue."Employee Full Name"}}
Smart values are case-sensitive, so I suggest finding an example issue with your field filled in, and then try the instructions in this how-to article to confirm the smart value name.  Basically, you call the REST API from a browser and then search for your field name and the data contents to confirm the name.
https://support.atlassian.com/jira-software-cloud/docs/find-the-smart-value-for-a-field/
For some automation syntax, you will still need to use the custom field ID rather than the name, so this technique will also find that information.
Best regards,
Andrew Vaughan July 25, 2021
Thanks, Bill - I expected those to work, too, and they did not.  I've double and triple checked the case; unfortunately, no dice.
I'll double-check the API in the morning, but the characters I posted was basically an example of me banging my head against the wall as I tried everything I could think of (including looking up the smart values). Will accept the answer or write back in the morning - thanks!
Like Bill Sheboy likes this
