Hello, I`m currently doing an automation on JIRA. It create tasks and subtasks based on external systems. Well, I need to transitions all subtasks issues when my parent issue is solved. Anyone can help me on this?
Hello @Gabriel Flavio
Create another Automation Rule that will transition the subtasks to solved when the parent issue transitions to solved.
When you are in the Automation screen there is a Templates section. There you will find a template for a rule that does exactly that.
I found it!
But, theres no way doing that using API?
Not with a single API call, no.
You would need to execute multiple API calls to retrieve the child subtasks of the parent issue and then transition them.
