Sub tasks in Microservice structured projects.
Ido Flaishon
July 14, 2021
I have a problem defining the ways of working in JIRA with my team. The issue is coming because of three points: agile practice, microservice structured JIRA projects, the function of a sub task. I would love to hear ideas how to deal with the situation.
Agile practice - Story is a vertical slice
It's the normal idea that a story should be a vertical slice. I expect a Story to be deliverable, an create value. Technical implementation should be sub tasks of the story. So if to delivery a feature I need to touch the Front-end and 3 services, I might have 4 sub-tasks attached to the story.
Sub tasks
Sub tasks according to my understanding are always a part of the main issue, and are tightly connected to a certain project. You cannot have an issue with sub tasks from different projects.
My team is working in microservice architecture, and opened a separate JIRA project for each service.
THE PROBLEM
I want to have a stories with sub tasks, but I can't since the sub tasks should be a part of different projects, each touching a different service and therefore a different JIRA project.
I know I can use Epics for this case, but for my understanding, epics for a larger scale issues, that might have multiple independent deliverables.
I can also link the issues and use dependencies, but then it's hard to visibly present on a board that all of these issue belong to a single User Story.
Any ideas?
Many thanks in advance!
Nic Brough -Adaptavist-
July 14, 2021
This is the crux of the problem:
" I can't since the sub tasks should be a part of different projects, each touching a different service and therefore a different JIRA project."
You need to decide if these issues are sub-tasks or not.  If they really are a part of a bigger issue, then your projects are set up incorrectly.  If they are dependencies, rather than part of the issue, then you should stop trying to think of them as sub-tasks.
