×Hi there,
My ultimate goal is to sum up story points from all subtasks, with Story parent. I am aware about the existing automation rule, however before actually start using it, I have a few questions:
1. In my Jira instance on subtask screen, I can bring only Story point estimate field rather than Story Points - is there a way I can bring Story Points field to the Issue Screen? The funny thing is - I can see both field added into Issue Screen configuration, however only Story point estimate field is visible after all.
2. If after all I should go with Story point estimate rather than Story Points, then in Automation rule condition for Parent story point value, should I add {{issue.subtasks.Story point estimate.sum}} rather than {{issue.subtasks.Story Points.sum}}
3. Apart from the above change, do I need to change anything else in the Automation rule - I assume the condition also should change to Story point estimate, right?
I have a couple of questions that may help the community to offer you suggestions:
Best regards,
Thanks for initiating the discussion @Bill Sheboy please find my answers below:
I am working with the company, where we are applying Agile SCRUM framework in a kind of evolutionary way, but we are aiming what's described in Agile Project Management. For the moment we think we realize how to map the main logical domains there:
So this is pretty much the idea behind this request. I hope now it makes more sense to all of you. Let me know your thoughts.
Thank you for your detailed explaination!
Regarding the field issue, have you tried the field admin helper, as it would appear a field is not present in a setting/context/view. Please look here for how to use the helper as you are a site admin: https://support.atlassian.com/jira-cloud-administration/docs/use-the-jira-admin-helper/
Regarding the sizing of sub-tasks, I understand your meaning and I further wonder:
One way teams address this issue is during refinement, the team asks questions to confirm a shared understanding of the request's "why" and "what", discusses the solution approach as a team, and then sizes together as a team. They may then compare to prior work to achieve sizing alignment with better accuracy. Tools like a "sizing ruler", triangulation, or "things that matter sizing" can help.
Thanks again for your ideas!
Thanks @Bill Sheboy - re Story - subtasks relation and SP calculation, you have a point, we will definitely address the issue. I think the key point here it to make sure, the approach, when we have a Story, which we can then broke it to subtasks is the best approach.
I tried to summarize all foreseen approaches I have in this discussion topic, I would appreciate if you or anyone else decides to provide their feedback.
Thanks agains!
