Swimlanes in Kanban board won't work with ticket from team-managed project
Anders Moberg June 7, 2022
I've got a Kanban board where I mix tickets from team-managed projects and company-managed projects. The Kanban board uses Swimlanes based on Epic tickets.
With the tickets from team-managed project, I'd imagine that they should also work according to the swimlane condition with Epics from the team-managed project, but no!
This seems to be lacking this scenario implemented. Hopefully someone can correct me, or Atlassian staff / devs could look at implementing a solution for this scenario.
John Funk
Hi Anders,
Is the problem that the Team-managed Epics are not showing at all on the board?
No, as I marked in my screenshot the Epic does show up for the project in mind, as does other tasks that is under that Epic. So the filter query should be setup correctly.
I'm just keen on having a swimlane appear by Epic (a.ka tickets in the TMP project show up in a swimlane associated with their Epic from a TMP project)
John Funk
Can you share the JQL you have for the Swimlane query?
I'm not using a Swimlane query, I'm using the "Epic" setting in the Swimlane configuration. Please excuse my native locale being active here
John Funk
Ah, that might be it then. Team-managed projects do not use the Epic Link field - they use Parent. So the built-in functionality of using Swimlanes based on the Epic with a Jira Software board is probably not going to work.
There is movement soon to replace the Epic Link functionality in Jira Software with the Parent concept, and it might begin working then - but that's a few months away.
Gah, ok. It'd be nice to get an ETA on that, but I'll take it as an answer. Thanks for responding.
Like • John Funk likes this
June 7, 2022
Hi @Anders Moberg
In regards to the switch to "parent" for such linking, please review/watch this thread for lots of details...and look for other posts in this Jira Software area:
https://community.developer.atlassian.com/t/deprecation-of-the-epic-link-parent-link-and-other-related-fields-in-rest-apis-and-webhooks/54048
Nic Brough -Adaptavist-
June 7, 2022
Team-managed projects are not built to be shared outside the team.
Currently, they only support Epics that are in the same project, and trying to draw TMP issues into cross-project boards is, I'm afraid, doomed to failure.
I don't accept this framing. TMP and CMP in the same Kanban board has gotten better and better with time. I felt like I've been able to use them in the cross-project boards no problem. It is just this hiccup I've gotten recently. It appears as a bug to me.
If it's doomed to failure, Atlassian should limit cross-project boards even more.
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
