Swimlanes with the new Epics and Features
Kevin Dickson
Ever since renaming Epic to Feature, and creating a custom Epic field (to follow SAFe's hierarchy), I cannot base my swimlanes on Epics - only Features, Stories, etc).
Is there a way to show Epics still - even though it's now a custom Epic field?
I would like to be able to still base my swimlanes on Epics, with them expanding to Features, and then to Stories
Kevin Dickson
Thanks Cassie,
Yes, we have Preium, and it does work there.
I think though, the team is still used to the old "standard" way of looking at things, so I will give them some coahing on advanced roadmaps.
Appreiciate your suggestion - will attempt that today
Marc - Devoteam
July 26, 2023
Hi @Kevin Dickson
So you renamed the Epic issue type to Feature, no then there is no option the have swim lanes based on Epic, but on Feature.
The issue type Epic (default) is the only type with this functionality.
The only option you would have is to base swim lanes on your based on queries. Then you are able to create a swim lane on:
e.g.
Epic = "value in custom field Epic"
Repeat this for each value you have
Kevin Dickson
Thank you, Marc. I'll try this and revert.
Like Marc - Devoteam likes this
Danut M [StonikByte]
Hi @Kevin Dickson,
If you do SAFe, this article on our blog might be useful for you: How to track multi-team or scaled-agile projects (such as SAFe®) in Jira with Great Gadgets app
As you will see, with our Great Gadgets app you can track all the SAFe-specific metrics!
In addition, the app offers a Team Wallboard dashboard gadget that supports swim-lanes by Epic. Here is an example:
I hope this helps.
Thank you,
Danut Manda
Kevin Dickson
Thank, Danut - I'll check it out this morning and revert.
Linh Pham_Ricksoft_Inc
Hi @Kevin Dickson
You mentioned that you want to "base my swimlanes on Epics, with them expanding to Features, and then to Stories" , so if I understand it correctly, the intended hierarchy would be  Epic - Feature - Story - Subtask.
But since you renamed Epic to Feature, your "Feature" issue type is now the parent level and Epic at the story level, you can't group issues on the swimlanes under Epic - it will only show sub-tasks.
Kevin Dickson
Thanks Linh
Cassie the Jira Mechanic
@Kevin Dickson are you talking about the advance roadmaps? If not to achieve this you will have to upgrade to premium to get advance roadmaps. Then you can update your Hierarchy this way:
Step 1. Go to the Jira Admin Settings cog and click issues.
Step 2. Click Hierarchy then tweak it to flow how you now want it. *this is a global change that affects the entire site and all its projects. I found this screen a little confusing when I first used it but read it top to bottom .. things bottom up roll into the things above.
**Oh, edited this to add that this additional level hierarchy will not show anywhere else but the tickets fields ( parent link is in use now in addition to epic link) and visually in Advance Roadmaps.**
Hope this helps!
