Syntax of Story point estimation in Advanced Search to get a range of numbers
Sara April 7, 2021
Hi, I want to filter my stories and tasks based on Story point estimation, to see the easiest tasks to do.
e.g. to see the stories which have 1, 2 and 3 as estimation.
Right now I can only do it by one number at a time.
Yuliia_Borivets__SaaSJet_
April 8, 2021 edited
Hi @Sara
Here is an example of JQL that worked for me to see the stories which have 1, 2, 3 as estimation:
project in (Marketing) AND "Story point estimate" <=3
Other option for you: if you don’t know how to set queries, you can try Dynamic Filters: JQL Replacer add-on. It's developed by my team to simplify advanced searches. So you can set the required request with help of Smart Field Manager as shown below: story points.png
Hope it helps.
Regards
Trudy Claspill
Hello @Sara
Welcome to the community.
This page and the related pages provide information about advanced searching.
https://support.atlassian.com/jira-software-cloud/docs/advanced-search-reference-jql-operators/
If you want to look for issues where a number field is within a range you would add criteria thus:
[field] >= [low end number] and [field] =< [high end number]
If you want to look for issues where the number field is set to any one of a set of specific values you would use the IN operator.
FREE
