×I would like to know if there is a way to modify the system dashboard so that users see different views and gadgets based on their permissions. I could not find anything on the documentation so far, I would appreciate any guidance here! Thanks.
Hi James,
what you'Re trying to achieve is not possible out of the box. There is just one "System dashboard" and it's not dynamic - thus identical for all users. So it's best to keep the sys dashboard generic and create group-based dashboards that can be shared with different stakeholders.
Christian
Hi James,
when you publish a dashboard you can choose if everyone should be able to see it ("shared with all users") or if it should be only visible for a certain user group. In your case you could handle the permissions via groups and then don't allow your freelancers (for example...) to see the dashboards for the admins.
Does that help?
Best regards,
Florian
