System admin permissions
Collista Lewingdon
I am attempting to bulk edit some issues in a project but have come across an issue. I am system admin and org admin. Jira is telling me that I do not have permissions in more than one error and I am at a loss as to where to look to see why this is happening. Any idea?2023-06-28 07_17_07-Bulk Operation - Jira.png 2023-06-28 07_17_33-Bulk Operation - Jira.png
Collista Lewingdon
Well, I figured it out. For some reason the system is not allowing me to add the system admin group to the project as admin and giving access. I had to add myself as a admin to the project and I was then able to access everything normally.
JM Perrot
Hello @Collista Lewingdon
Are you added in each concerned projects ? If yes do you have all required permissions in these projects ?
Can you check your global permission ( Global settings -> Global permissions) and your project permissions in each affected projects by bulk change)
In global permissions you need to have the "Bulk change" permission but I think this one is ok.
In project settings you need the right to delete issues and to edit issues, to move issue (if you want to change project for these issues), to transition issue (in addition to close and resolve issue issue for green statuses )
JM
Fredrik Dahl
Hi @Collista Lewingdon
Even though you are a ORG you will need correct permissions for the project.
If you go to the Project and then in the left hand menu select Project Settings -> Permissions
Make sure you have the correct permissions here to i.e. Link Issues would be one of the permissions you are lacking. Especially make sure you have the Edit Issues permission.
Depending on how the permission scheme looks you might need to add yourself to a group or a project role.
