There is no way to make the system dashboard private. You never want to, as it's the landing point for users who have not chosen something else.
Jira and system admins can amend what is on it.
If you're worried about "leaking" information that you should not, then the system dashboard respects the permissions and visibility that you set in the project level - if you can see something on the dashboard, making the dashboard private is of no use, the issue that it's reporting on can be seen and that's where you need to think about the privacy
Thanks for the response Kagithala Babu Anvesh, but I was referring to "System Dashboard" with no owner associated with it.
Seems like it has to be public, and we need to set the global permissions correctly so that the content is not exposed to not-logged in users, reference: https://community.atlassian.com/t5/Jira-Software-questions/How-can-I-make-System-Dashboard-private/qaq-p/1079013
Hi @Kiruthika ,
Are You jira admin, if yes
Go to Dashboards -->View all Dashboards -->
Click on settings (...)
Edit and Share Dashboard
Choose the settings from the dropdown as below
There isn't an option to mark the "System Dashboard" as private in Jira Cloud. The interface you showed is what is possible for every other dashboard other than the "System Dashboard".
