The new UI seems to have forgotten tables and panels.
I have a custom field for Acceptance Criteria and use tables and panels to organize the contents.
I had it nicely set up then the new UI arrived (with no warning I might say). Now I cannot edit my tables easily, cannot find out how to add a new panel.
I might say that I used to 'code' everything exactly how I wanted/needed it, then you made it point and click and now I don't even know how to do that.
The "New Editor" was rolled out, not that long ago, and some things did change.
Maybe you can add some detail about your use case. This is tagged for Jira, so are you talking about a Dashboard? Since you mentioned panels, maybe you were using Confluence?
More information will help us to help you.
