I have a structure with different issue types with target start and end dates.
Ex: Feature >> Story >> Task >> sub-task.
Start Date End date:
Feature 12/Jul/22 30/Oct/22
Story 12/Jul/22 30/Sep/22
Task 14/Jul/22 10/Oct/22
Sub-task 15/Oct/22 30/Oct/22
I need to help to write formula on the Start Date and End Date columns to extract Feature start date is the start of the date and end date should be end of the entire feature (means story, task and sub-tasks must be closed) date - 30/Oct/22. I noticed there are Min and Max functions in Expr but I am not able to get the dates.
Any help will be really appreciated.
Hello @sarathgd ,
David from ALM Works here.
Is the goal to set the value at the feature level? Or to visualize the start and end dates from the issues below the feature in a separate column? At the moment, it is not possible to set the value, but we can visualize the difference via a formula.
In either case you will want to use the MIN and MAX functions with a modifier, probably #children based on your example.
The formulas would look like this:
MIN#children{startdate}
MAX#children{enddate}
You can add them as separate formula columns to see the results. You may need to map the start and end dates to the appropriate fields.
Please let me know if this helps, or if there is any additional criteria you would like to add.
Best,
David
