×Hi Everyone,
Question that I received from one of our staff this week. They are running a project using a Team-managed Jira project. They have created all of their Epics, Tasks and Sub-Tasks and when in the list view they can see all of the Tasks under the Epics they belong. The Epics can be expanded and collapsed so that the view only show Epics and then when he wants to drill down on tasks within a specific Epic the Epic can be expanded.
The question is when going in to the Timeline and Board view the tasks are not presented as children within Epics. This means for the Timeline view the tasks with in Epics can not be expanded or collapsed and appear as separate line items. The same also happens in the Board view, each Epic and Task appears as a separate unrelated card on the board. If an Epic that contains children tasks is moved to another bucket on the board only the Epic moves and its child tasks incorrectly remain in the original bucket.
Does any one know why the Timeline and Board views behave differently compared with the List view? It looks like a bug.
Any advice or guidance welcome, thanks.
Hello @Leigh Elliott
Timeline is a feature of the Work Management/Business project type. Can you confirm for us that is the type of project in this scenario?
If you are working with such a project, it appears that nesting child issues under an Epic in the timeline view is not yet supported. Refer to
Looks like this is exactly the issue we are seeing, so I guess I'll have to wait until the functionality is built.
+1 in voting this as an important issue to resolve. For any marginally complex project, nesting tasks below epics is a key feature to make the timeline useable.
@Adam Miladinovic @Ulrich Scharf
Make sure that you add your votes to the issue itself. "Voting" on this post in the community does not add a vote to the issue itself.
If you don't need to use Epic and are willing to e.g. use Task as a substitute until it's fixed you can work with sub-tasks in the timeline. Only an option if a 2 level hierarchy is enough tho.
+1
This feature alone is why I use Jira Software instead of Jira Work Management.
The only people that care about timelines are my business projects (software runs via agile), and the inability to see the tasks in an epic makes epics literally useless.
But Jira Software neatly displays or hides epic children with the click of a button.
However, Jira Software does not display sub-tasks, while Jira Work Management does fold up or display sub-tasks with the click of a button.
How is this not a joke? Seriously: how is this not Atlassian just punking us for laughs?
JWM shows task children but not epic children; JS shows epic children but not task children.
+1 for this feature, especially considering software has this feature. Would want to see the grouping filter applied with 'epics' as well in the same way.
Hey Guys,
Help us get this issue resolved by clicking this link then voting:
https://jira.atlassian.com/browse/JWMCLOUD-111
Also, share this on any other issues you are watching so Jira implements it faster.
Isaiah
if this isn't fixed would consider just leaving jira
If institutional inertia did not exist, neither would Atlassian.
I can't believe there isn't a better system out there, somewhere; but I can't be bothered to search for it because management already bought into this one.
And honestly, Jira is good enough. It is the literal definition of bad software design and development, but it can get the job done as long as you don't care what it looks like or how hard it is to do the job.
The tyranny of gargantuan mediocrity. It's a metaphor for modern life.
