×I cannot locate this answer. I am a JIRA Admin. I can usually log work for another person by way of the Tempo Log Work dialog. I've discovered today dozens of people (after a brief look) that I cannot log work for. For instance, if I type in a known name, it does not return a match. I have looked at people's user configuration that I can log work for and they match exactly to those I cannot log work for. What gives?
Hi Paul,
To be able to log work for other users you must have; Approve Timesheet for Tempo Team, Allow user with Approve Timesheet permissions to log work for others (Global Configuration) and Browse User Permissions (to lookup user name)
I hope this helps.
Best regards,
Sigrún
Tempo Support
Thanks very much, Sigrun. I thought I was pretty savvy with Tempo. Always more to learn.
A simple (and supported) solution is to use this plugin:
Log work as another user
That allows you to log work on behalf of another user of your choice.
Regards
