I'd like to be able to add the Log Work dialogue to a transition screen to remind developers to log their time. Has anybody figured out a way to do that?
Hi @Nicole Helgeson ,
Here's Tempo's new(ish) idea portal where you can vote/comment/follow ideas:
https://ideas.tempo.io/ideas/T-I-358
On the idea, Hlynur (Tempo PM) has updated in the past few months - unfortunately, looks like the ball is still in Atlassian's court for this.
Carolyn
Tempo Customer Success
Hello @Nicole Helgeson
Sadly, I have not found any documentation to say it is possible though I would like it to be also. You can however put in a workflow condition to check some time has been recorded against the issue before the workflow transition occurs.
i would also recommend reaching out to Tempo and raising a support ticket to request this feature.
Hope this helps,
Danny
