The same project in 2 scrum boards
Sona Evanesyan
I have a problem with moving a project from one board to another. It is seen in the first board as well, while I need it only in one board.
p.s. In Board settings the project is included only in one board, and one filter .
John Funk
Hi Sona,
It is the filter attached to the board that determines which cards show up on it. What do the filters for the two boards look like?
Trudy Claspill
Boards are just a way to view information in projects. You can have multiple boards to view the information in a project.
The issues are in the project, not in the board. Making another board to view issues in a project has no impact on what is seen by the other boards. However, actions taken through one board on an issue that is visible in multiple boards will impact the view of that issue in all boards.
If you want only one board for viewing the issues in a given project, you will need to delete the other boards that view issues in that project.
Register now
