I have a task...
It should show 0h or -1h remaining ... help...
image2014-11-7 5:56:35.png
The time remaining is not always calculated based on Estimated - Logged. You have an option to update the time remaining when a time is logged (i.e. because the original estimate may not always be accurate).
Check the history tab to see if "Time remaining" was manually altered or not.
Ah, no. Estimated = 3d 1h. That's not the original estimate, it's the current. 1d 6h left to go, and logged 3d 2h. Have a look at the history, you should see the original esttmate is 4d 7h.
