Time tracking per project
Lotte Pijnenburg January 18, 2023
On our global settings, the Time display format is set to Pretty (e.g. 4 days, 4 hours, 30 minutes).
But, in our backlog - the time tracking is set to 'days'. We use team-managed projects.
Any idea on how to set the projects time tracking values to pretty?
Gr,
Lotte
Trudy Claspill
Hello @Lotte Pijnenburg
Can you provide a screen image for what you see in your backlog? Are you see fractional days as decimals instead of hours and minutes?
Lotte Pijnenburg January 19, 2023
The first (gray) view should be like x days, x hours, x minutes but it is viewing it indeed as fractional days as decimals.
Trudy Claspill
In your Global Settings, what do you have your "Default unit for time tracking" set to? I see what you see when I have it set to Days, but if I change it to Minutes then I see the #d #h #m format.
It's set to minutes... So indeed I should be able to see the d h m ... :(
Trudy Claspill
I apologize for taking so long to get back to you.
So far I have not been able to recreate what you see, with the Global Time Tracking Settings using Minutes for the Default Unit.
I advise you to open a support case directly with Atlassian to investigate this more.
https://support.atlassian.com/contact/#/
It would be wonderful if you report back here what you learn.
