We would like to add an hourly budget to each individual task. And then we would like to have a field with the actual time needed and a field with remaining budget.
In the end we would like to have a sheet with data so we can work with the data.
Has anyone a solution for this?
Thank you in advance.
Hi @Miguel Weber maybe what you need is an app like the following
https://marketplace.atlassian.com/apps/1214127/abacus-jira-calculator?hosting=cloud&tab=overview
That should allow you to do math based on the value of your other fields.
Exporting to an Excel is simple as suggested by @Lenin Raj
If I understand correctly, you are looking to add custom fields to each issue/task. Yes this is possible, have a look at https://confluence.atlassian.com/adminjiracloud/adding-editing-and-deleting-a-custom-field-776636410.html
If you want to update the remaining budget field automatically when another field is updated, you could try https://marketplace.atlassian.com/apps/1215670/automation-for-jira-cloud-lite?hosting=cloud&tab=overview
To export the issues to an excel sheet, see https://community.atlassian.com/t5/Jira-questions/Jira-Export-Custom-Fields-to-Excel/qaq-p/746870
