Currently we have an approval status baked into our workflow, and users are not able to work on tasks that have not been approved. I need issues created by various managers (1-2 people specifically) to be defaulted to this approved status to help streamline the process for them. Any insight?
Hi Amber,
if I undersootd you correctly you want that issues created by reporter A or B to go "directly" to a approved state.
I'm not remember anything that gives you that direct flow, but you can have something simillar with:
https://confluence.atlassian.com/display/JIRA/Jelly+Tags
https://confluence.atlassian.com/display/JIRA/Jelly+Escalation
Setting a service to run a jelly script i na given period of time ( secounds) that would catch any issue in Open state createb by "managers" and automatly make the transition of the issues to the state you need.
Can this be used by an on demand instance?
Hi Amber,
JIRA Enhancer Plugin has Assign to a User in a Role and Assign to a user in a role, based on a field of issue post function workflow postfunctions.
You can check and watch screencast on site www.jiraenhancerplugin.comand documentation page.
However, at the moment it is not available for "on demand" instances.
Tuncay Senturk
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
