Transition parent based on sub-task
Ryan Paul
Hi!
Can you help out with an automation rule where I have a parent and multiple sub-tasks?
If one out of 3 sub-task is moved to In-progress, the parent should automatically change to In-progress.
And if the sub-task that was in progress is moved to To-Do, the parent should automatically change to To-Do.
Mindaugas Dūda
Hello @Ryan Paul
You can use the following automation rule:
When issue transitioned FROM "To Do" TO "In Progress"
For Parent
Then: Transition the issue to "In Progress"
Example below:
Note, to transition back from "In Progress" to "To Do" you will need to create another rule with same logic.
Hope this helps.
Mindaugas
John Funk
March 6, 2023
I would add that you probably want some type of Condition after the initial trigger to further define which issues you want to limit.
Ryan Paul
@Mindaugas Dūda @John Funk It's working! Thanks for helping me out...
Like # people like this
Mindaugas Dūda
Happy to hear this :)
Like John Funk likes this
John Funk
March 7, 2023
Same here - glad it is working for you.
