×We have stories with often 5-7 tasks associated, and from 1 or 2 of those tasks, we have bugs cross linked to other projects.
for Example:
PRD-1 (Story)
PRD-2 (Task - linked to PRD-1)
Linked to JOB-1, JOB-10, JOB-47. (Because Task PRD-2 was to make more work for JOB team)
I'd like to make a report that allows me to use my filter which is defined as "IssueType = Story"
project=PRD and linkedIssue in linkedIssues("PRD-1")
works - but is limited as I have 50 of those things I'd like to view.
But my search:
project = PRD and linkedIssue in linkedIssues("IssueType = Story")
Fails.
As does
project = PRD and linkedIssue in linkedIssues(Filter = My50Filter)
project = PRD and linkedIssue in linkedIssues("Filter = My50Filter")
All error out with "Issue 'Whatever in parens' could not be found in function...
Would appreciate any help!
Hello @Lisa Napier ,
The JQL "linkedIssues" that you are using only work for a single reference issue as the source. The values are relying on the source issue to define an individual issue to reference a source, but there is not a method to pass in multiple issues, and we have a feature request tracking interest in this at the following link. Make sure to add your vote to the request:
The Method that @Vinod Ramadoss mentioned would praobly be the best workaround for what you are looking to achieve but also require the third party add-on app ScriptRunner for Jira which has the mentioned additional scripted JQL functions that can isolate for link types on nested filters, as noted above via the "issuefunction in linkedIssuesOf('filter = "AB"')" JQL, some details can be seen on the Adaptivist documentation for scriptrunner here:
And some additional recommendations on using this function provided by ScriptRunner in the following Community posts where other users were looking for a similar action and this tool was the recommended solution:
An alternative approach would be to narrow down the results using the link types and statuses in the JQL with something like
(project = PRD and issueLinkType = "is blocked by") OR (project != PRD AND issueLinkType in (blocks))
Another option is to incorporste open sprints if you wanted to isolate issues that are currently in the works that need attention and also trying to incorpoerate labels in some way to make the issues more distinguishable, however labels would require manual processes for the end users to add said lables in advance when the linking actions are taken, and has the potentioal for user error.
"project = PRD AND issueLinkType = "is blocked by" AND sprint in openSprints() AND labels = LABEL_NAME"
I recomend checking out the natively available JQL options in the following reference material to help narrow things down a bit further:
Earl
Hi Lisa,
For such scenarios I generally use jql
project = xyz and issuefunction in linkedIssuesOf('filter = "AB"'), try and let me know if you are able to get your desired results.
Hi Vinod, That didn't help.
I don't have issuefunction available, and linkedissuesOf isn't available either.
When I use issuekey in linkedIssues I get the below error.
"filter='MyFilter''' could not be found in function 'linkedIssues'.
The same query works fine with
project=PRD and issuekey in linkedIssues("PRD-1")
But I get the error message: Unable to find JQL function 'linkedIssuesof(PRD-1)'.
When attempting to use that syntax.
Unfortunately, due to our current plan & limited use of this function - I'm not going to get plugin approvals any time soon.
Hi @Zeeshan Hasnain Could you please help me how you resolved this issue as I am looking for the similar thing.
