Hey does anyone have any advice on how I can add cucumber format conditions into the UAT text field so that it always appears when creating a new task?
For Example -
Feature:
Hello, @El ! Welcome to the Atlassian Community!
If you're a Jira administrator, you can change the Default Value of your Acceptance Criteria custom field to add the Gherkin format conditions.
From the area to configure Custom Fields:
And then select Edit Default Value in the resulting screen
