Un-block other projects
Matthis Thorade
In our company, we have three projects, let's assume they are named OCT, TML and AFP. I work in the TML project, and would like to do two things:
  • find a list of all stories where TML is blocking the OCT or AFP project
  • find a list of all stories where TML is blocked by OCT or AFP project
Using JQL, I can easily use the following queries:
project = "TML" AND issueLinkType = blocks
project = "TML" AND issueLinkType = "is blocked by"
but then the majority of stories in the list is of type TML blocks TML, or TML blocked by TML.
How can I filter out the issues/stories where we are blocking or are blocked by a DIFFERENT project only??
Kevin Johnson
Hi @Matthis Thorade ,
This kind of filtering is not possible in jira as of now. Instead these are some plugin which will help you achieve this
Hope this helps.
Here's a link to similar ticket : https://community.atlassian.com/t5/Jira-Core-questions/Query-to-find-jira-issues-in-one-project-that-are-linked-to/qaq-p/1332315
Kevin.
Matthis Thorade
Thanks. This is a pity, I cannot buy any apps/extensions. This seems quite basic functionality to me.
Like • Kevin Johnson likes this
Prince Nyeche
April 23, 2021
I'm not certain if this would be what you're looking for but I would try it like below
issueLinkType in (blocks, "is blocked by") AND NOT (project = TML AND issueLinkType in (blocks, "is blocked by"))
Kevin Johnson
@Prince Nyeche I guess this will list all the linked issues in other projects, not the issues in the specific project which has only linked issues with other projects.
Prince Nyeche
April 23, 2021
Hmm, I thought as much.
