Unable to Compare timestamps fields in JIRA cloud
Neha Dua February 4, 2021
Hi I need to compare two time stamps fields in Cloud JIRA  and I got script runner installed When I used the  JQL issuefunction in datecompare("", updated>created) this seems to be working in the jira server.
When tried to replicate same in Jira cloud, its throwing error- Field 'issueFunction' does not exist or you do not have permission to view it.
I checked script runner docs its saying  "the date compare function in the middle of the expression is not natively supported by JIRA Cloud. "
mentioned in below link.
https://scriptrunner-docs.connect.adaptavist.com/jiracloud/enhanced-search.html#_troubleshooting_tips
So looking for any other way to compare 2 time stamp fields , Can someone please assist on this.
Kristian Walker _Adaptavist_
Hi Neha,
Thank you for your question.
I can confirm that you can only use the ScriptRunner for Jira Cloud functions on the Enhanced Search page as described in the Knowledge Base Article here.
Also, I can confirm you can see examples of how to use this query in the cloud version in the documentation page located here.
I hope this information helps.
Kristian
Hi Kristian ,
Thanks for quick response but we tried all options and unable to see the enhanced search page . It looks like enhanced search addon  is needed to buy separately from this script runner.We dont have that .
I can see script runner under apps , checked with admin as well.
Moreover I need to use this query in  JIRA REST API calls .
Could you please assist how I can write this query in any other way so that I can get it worked .
February 4, 2021 edited
Hi Neha,
I can confirm the enhanced search add on is not needed.
Scriptrynner provides the *enhanced search* page as long as it has been turned on the Settings page which is located in your instance at <JiraCloudURL>plugins/servlet/ac/com.onresolve.jira.groovy.groovyrunner/settings?s=com.onresolve.jira.groovy.groovyrunner__settings by toggling on the ScriptRunner Enhanced Search Setting as described here.
Once this enabled you will then see this as an option In the Apps dropdown menu.
Kristian
