×Hi @Ujjal Goswami,
without further informations its very difficult to help.
Please post the error message from the atlassian-jira.log.
Oliver
In the System Info,I couldn't find the path of the at;assian-jira.log file.Please see the attached screen.
image2016-2-4 18:9:41.png
You are on Cloud. You do not have access to the logs. You will need to raise this with Atlassian Support directly, as they can read the logs.
From where to raise the issue to Support.Can you please guide?
Terribly sorry, I forget to add that sometimes. https://support.atlassian.com
Check atlassian-jira.log and find mare detailed information.
