I am trying to integrate my jira project with monday.com.
monday.com requires an API token - for which I went to jira > account settings > security > API Tokens.
But the problem is that there is no option for me to create an API token.
The API token page only shows that it has failed to load any API.
Screen shot attached. any help much appreciated!
thanks,
Chetan.
Ok. so the fix was way too simple. just log out and log back in. and kept hitting retry button.
thank you for this! i had the exact same problem, and you coming back to answer your own question saved me a bunch of time.
No success. Logged out 5 times already and still the same. Console log says 400.
Same here. Error 400
Same here.
