×I am Seeing the below error
Hi @bindu madhavi Bagusetty and welcome to the community,
The project you are in is using a certain field configuration scheme. In that scheme you will find the individual field configurations for your issue types. For that specific issue type, the label field is set to hidden. To unhide it:
keep in mind that if that field configuration is shared with other projects, the label field is going to appear in the shared projects as well.
The field Labels is hidden in the field configuration associated with the project. Click on the Link Go to "Default Field Configuration" and click Show next to the Labels field.
