Unable to delete cards, but I have the right permission?
Camilla Hvid Jessen
October 20, 2020
I am unable to delete cards on a board that I'm in, in spite of the fact that I have the correct permission to delete (see screen shot above).
Anyone knows if there's a way I can fix this?
And otherwise - how can I report it as a bug to Jira? (Been trying to access a support of some sort, without any luck)
Thanks! 🙏
Flavien Gache
Work log means the time you spend on a Jira task. It is different from the permission "Delete issue". See if you have that permission and tell me if it helped you solve your problem.
Eduardo Santos
October 20, 2020
Hi @Camilla Hvid Jessen
That permission is actually for the work logs entries and not for the cards. The cards on the boards are the issues itself, so you must have the delete issues permission to be able to delete a card.
Best regards,
Eduardo
Roberto Miasack
October 20, 2020
Camilla, hi!
You need this permission for delete cards:
Delete cards.PNG Kind Regards
Miasack
Read the story
