Unable to find a field in the Context or Custom Field in Jira Project
Neeraj Prasad Dev July 19, 2023
Hi Team,
can you please help on this, we are facing the issue to find a filed in our  specified Jira project:
Checked the Screen, Context, Custom fields.
Regards
Neeraj
Prerna Sony
July 19, 2023
Hello @Neeraj Prasad Dev  , Welcome to the Atlassian Community!
If you can't find a custom field, you can use the Find your field function on the issue view to find it.
To find your custom field:
  1. Open an issue.
  2. Select ··· > Find your field.
  3. Search for the field you want to find.
  4. Select the field.
A table with the field’s status, admin-related settings, and details will display information about where you can find the field or why the field isn’t displayed on the issue view.
Hope this helps.
Thanks and Regards,
Prerna
