In Jira Work Management,
In the "List" view
While trying to create a "Format Rule", I'm unable to find the custom field called "Event Type". The field is a single select drop down. I can create other rules that work fine.
Hi @Sean Still -- Welcome to the Atlassian Community!
If you start typing the field name in the field, does it filter the list and then appear for selection?
That field appears to be a Jira Work Management (JWM), "dropdown" field type, which seems unsupported for format rules and different from a single-selection option field type: https://support.atlassian.com/jira-software-cloud/docs/create-a-format-rule/#Supported-fields-for-format-rules
However, I also found other listed field types do not work consistently in format rules. For example, the Radio field type can be selected but cannot filter correctly.
After a quick search of the public backlog, I did not find this symptom noted. I recommend working with your Jira Site Admin to submit a ticket to Atlassian Support to take a look at this one: https://support.atlassian.com/contact/#/
When you hear back from them, please post what you learn to benefit the community. Thanks!
