Unable to link newly created issue type to existing workflow
Kay March 30, 2021
I created a new issue type, and attempted to link it with a pre-existing workflow within a specific project.
This is the exact same process as carried out yesterday for a different issue type.
However, this time, I get the message "A issue type with ID '11509' does not exist.".
I deleted the issue type entirely, and created a new one (with a different name), and attempted to do the same thing again, but the error message came back again, with a different ID# value.
I looked through info available, but the best I could find was a suggestion to remove something from a database, which I am unable to access.  If I go to the workflow, I can amend it with no issues, but the issue type created is impossible to link with *any* workflow.
Kay March 31, 2021
John Funk
Hi Kay,
Can you list the exact steps you did?
Also, can you include a screenshot of the error?
Kay March 31, 2021
I created my issue type, went to workflow schemes, selected my scheme and attempted to assign my new issue type to the workflow I wanted to use, but got this message.  Not ten minutes previously, I had done the exact same thing with another new issue type, added to the same workflow, no problems
John Funk
Did you add the new Issue Type to the Issue Type Scheme used by that project?
Kay March 31, 2021
Hi John,
Yes, I did.
Turns out this is a known issue, and so Atlassian Support had to go and fix it for me :)
https://jira.atlassian.com/browse/JRACLOUD-43260
Like • John Funk likes this
John Funk
Thanks for finding that and sharing it!
