Unable to send linked issue keys in slack notification
Andrew
Hi Team,
I am trying to create an automated rule that can send a slack notification where the message will contain both the issue key and the linked issue key. The issue that I am facing is that the linked issue key is not coming through on the message. I am following the smart values documentation but does not seem to work or I am doing something wrong.
I am using the JSON extension to find the linked issue fields. When I navigate to the linked issue, in the footer it gives me the following
fields.issuelinks[0].outwardIssue.key
 I added this to the slack message using the different combos
{{issue.fields.issuelinks[0].outwardIssue.key}}
{{fields.issuelinks[0].outwardIssue.key}}
{{issuelinks[0].outwardIssue.key}}
None of the above worked and no key is being sent in the slack notification.
Any help or guidance would be much appreciated
Andrew
I managed to figure it out. I removed the [0] and that did the trick ;)
