Unable to start Jira after installing trial version
Saira June 26, 2019
I've installed Jira trial version (30 days) today. After installation got a blank page.
Can't reach this page.
https://www.atlassian.com/software/jira/download
is there any other link to download Jira Cloud.
Please help to resolve this issue.
Saira
2 accepted
Nic Brough -Adaptavist-
June 26, 2019
If you got a blank page, that implies something is running (the Tomcat that Jira runs on), but that there is something wrong (Either Jira has not started on top of Tomcat, or there's a block somewhere).  Could you tell us what url you are using and where Jira has been installed?
Could you read the log file to see what the service is doing?  It will be <jira home>/logs/atlassian-jira.log - does that show Jira running ok, or are there lots of errors in it?
No, you cannot download Jira Cloud, it is a service you subscribe to.  The link you have given is to the download for Jira Server, and that link is working fine for me, it takes us off to the download archives.
Saira June 26, 2019
Hi Nic,
I've downloaded Jira software server using this url:
Post installation, got blank page while accessing Jira - localhost:8080
also checked the logs, no errors were found.
after 30 mins finally got the Jira setup window.
Saira June 26, 2019
set up is pretty slow. a suggestion that this should be included as a note in documentation (trial version)
its taking long time for the services to start & set up Jira trial version
June 26, 2019
Ahh.  Yes, it does take quite a bit of resource to get a Jira running.  (Frustrating, I remember times when it was so small it started in under 10 seconds)
PVS
Banned
June 26, 2019
Hi @Saira
Could You Please Try Use the  Internet Exposer Browser . In This Browser its work
https://www.atlassian.com/software/jira/download Only this is the main link
Saira June 26, 2019
I've used this link to download on IE browser. after installation, it is showing blank page with this url.
http://localhost:8080/
Saira June 26, 2019
is it possible to have a remote session
PVS
Banned
June 26, 2019 edited
I will Give the proper information
PVS
Banned
June 26, 2019
First Shutdown the jira and Clear the lock and Plugin data
What is the data base Your Using ??
mete.c June 26, 2019
Hi Saira,
you cannot download jira cloud, only server products can be installable.
If you install jira sofware server, which link do you use for access it ?
Check if you have :
  • "Atlassian JIRA" windows service running
  • Compatible database installed
do not hesitate to add a screenshot
Regards.
Saira June 26, 2019
Hi Mete,
I've downloaded Jira Software server using this url:
after installation, got blank page : localhost:8080
after 30 mins finally got the Jira set up page - Finishing your setup.
Like • mete.c likes this
PVS
Banned
Ok
