Undocumented Markdown syntax for tables etc.
Christoph Päper
The Markdown syntax documentation for Jira Cloud does not cover table markup yet.
If you add or edit an issue description or comment through REST API or Automation, starting a line with a pipe character `|` and putting another one between cells and one at the end, Jira will recognise this as a table row. This does not work in the frontend editor (anymore), there you could type `/tab` or hit Shift+Alt+T. That‘s probably why it’s not documented.
However, Jira does support a header row (and column) in tables in the frontend editor. It is sometimes suggested that all you would need to get this from Markdown, is a second row whose cells only contain a run of hyphens `-` (as in many other Markdown syntax extensions) – this is wrong!
| Column Header | Column Header |
| Cell Content | Cell Content |
Through guesswork, trial and error, I found that you need to use double pipes instead:
|| Column Header || Column Header ||
Actually, every cell that is preceded by a double pipe will be treated as a header cell (i.e. `th` in HTML), so one can also get row headers:
|            || Column Header |
|| Row Header | Cell Content |
Has this been documented by Atlassian anywhere?
Is there any other undocumented Markdown syntax, e.g. for setting column widths or their horizontal alignment, or for adding colored status codes?
