Uninstalled app TestRail for JIRA Test Management and new install TestRail
marinazabrodska8
January 22, 2022
Hey!
I have a problem with re-installing the TestRail app for Jira. After uninstalling, I can't find the TestRail installation block in the Jira.
I need to re-install this app, how can I do that?
Thank you
https://prnt.sc/26hn4ho
I tried uploading this app but without a result
 https://prnt.sc/26hn6ds
Vishwas
January 23, 2022
Hey @marinazabrodska8
While going through the logs, yes i can see the app was installed and uninstalled.
In this marketplace URL https://marketplace.atlassian.com/apps/1213701/testrail-integration-for-jira?hosting=datacenter&tab=overview it shows only DC/Server app but for cloud it's not appearing. Not sure what could be the reason. But when we check in marketplace it is mentioned contact vendor for cloud supported app.
From this URL https://www.gurock.com/testrail/docs/integrate/tools/jira/cloud/ they have mentioned the same like app should be there for Jira cloud also. It's confusing as they have the same steps mentioned for Jira Sever/DC too.
Please try contacting gurock support team to get the information on plugin.
Vishwas
marinazabrodska8
January 23, 2022
Hello!
 I don't really understand what you mean.
 I was using this app and accidentally deleted it.
Screenshot of logs in attachment.
 https://prnt.sc/26i4xp8
Shanu Mandot February 17, 2022
@marinazabrodska8 Hello Marina,
Thanks for reaching out! Shanu here from the TestRail team.
I am happy to help you get connected with one of my colleagues that can help. Could you do me the favor of sending an email to contact@gurock.com with a description of your issue/request so that we can get you connected to the right folks on our side who can help? That way we can help get this resolved as quickly as possible.
Vishwas
January 23, 2022
Welcome to Atlassian Community !!
From Atlassian Marketplace I could see that "TestRail Integration for Jira" is app supported only for Data Centre/ Server variants of Jira.
You are using Jira Cloud, Hence you cannot find in the search and cannot upload and install also. Having said these we are not sure how did you get to install it in the first place ? Is it a different app ?
Hope this helps !!
Vishwas
FREE
Learn more
