I need to keep both the story and the task I just accidently linked two of the wrong ones together. Is there a way to un-link them and keep both or do I need to delete my task and add it again afterwards?
@Kati Samson , Welcome to the Atlassian Community!
You can unlink and keep both without any problems.
If you didn't linked the issues using this resource, can you share a screen to see what type of link you've applied?
Fernando
