Update parent issue when all subtasks are moved
Emerson
Hi everyone!
Creating an automation to synchronize status is very easy. The problem is, when you move the first subtask, the parent item also moves along. And I want it to only move when the last subtask changes status. Help me, please!
5 votes
Mark Segall
Hi @Emerson - You'll want your rule to look something like this:
  • TRIGGER: Issue Transitioned
  • BRANCH (Parent)
    • CONDITION: All subtasks match the following JQL
      • status = Done
    • ACTION: Transition Issue
Emerson
Hi @Mark Segall - In "status = Done" I want to change to "status != Parent Item Status". How do I represent this in JQL?
Mark Segall
To clarify, are you saying you want the condition to check for when all child statuses no longer equal the same status as the parent?  If so, it would be something like this:
status != {{issue.parent.status}}
Emerson
It worked when I changed to "Delivered". When I changed from "To Do" to "Doing" the parent has not changed.
Mark Segall
Are you getting any errors or it's simply not passing the condition?
Simmo
October 11, 2022
Could you include a screenshot of the rule configuration so far?
Emerson
That's the rule so far. I'm not sure if it's right, but works when I move the subtask to "Done".
Mark Segall
It looks like your last step is "Same Status (loop)".  You should change it to Copy From Trigger Issue
Emerson
I changed it to Copy From Trigger Issue and when I moved the subtasks from "To Do" to "Doing", the parent item didn't move along.
He only equaled the status when he went to "Done".
Mark Segall
I think I see the issue.  It's your condition.  You should not be using parent status.  You're already branched into the parent so it won't have a parent and thus, the status is failing to pull anything in.  The condition needs to be this:
status = {{issue.status}}
where {{issue}} = the parent issue because you're branched into it.
Make sense?
Emerson
IT WORKED! Man, you're awesome and a genius!
Thanks a million!
Like • 2 people like this
Thomas Evans
May 3, 2024
Hi there, I followed the above and it's working great, however, say for example I have 10 sub-task, I only want them to change the main parent card's status once all of them are the same. Is this possible, if so how?
Currently, when I change 1 status the whole card moves?
FREE
