Updating Jira issues with Jira Cloud for Sheets
Silver Salonen
Hello.
I would like to update Due Dates of Jira issues from the dates entered in Google spreadsheet. Is this possible in any way?
2 accepted
3 votes
Jack Brickey
You can import issues from CSV and update existing issues. create-issues-using-the-csv-importer . While that doc is about creating it works for update if you include the current issue key in the import file.
you could consider using the Jira API to update issues as well.
Hannes Obweger - JXL for Jira
Hi @Silver Salonen
yet another option would be to copy/paste the values over using the app that my team is working on, JXL for Jira. This is how this looks in action for the summary (it works the same for due date):
Just be cautious that you are pasting into the correct set of issues.
Hope this helps,
Best,
Hannes
FREE
Learn more
