I would like to share my perspective on the process of creating defects at the sub-task level.
It has been requested that defects be created at this sub-task level; however, I have a different preference. Instead of categorizing defects as sub-tasks, I believe it is more effective to classify them as Bugs and include a field that specifies the environment level. This approach will provide valuable information for the development process, particularly regarding the locations where error codes were discovered.
Furthermore, I recommend linking a Bug to a Story to indicate that it "blocks" the delivery of that Story. Utilizing Issue Links is beneficial as it clearly demonstrates that while a Bug may be a dependency for a Story, the work involved in analyzing, fixing, and resolving the Bug remains separate.
This separation allows for distinct delivery based on priority or severity. For instance, a Story can be completed even if it has a minor defect, whereas a production bug may not always be addressed immediately. I also find it advantageous to track Bugs and Stories concurrently on a board, as the Issue Link effectively treats the Bug as a "sibling" of the Story.
I also think that will allow better reporting without complex filters in native dashboards or EasyBi.
I firmly believe that using Subtasks with “defects” name is not the correct approach and can lead to a complex reporting environment. I would greatly appreciate hearing your opinions and observations to help me make the most informed decision regarding this matter. Additionally, I think it would be beneficial for my team to understand the reasons why using subtasks may not be the best strategy.
Hi Marcela,
Thanks for starting the discussion. And because it is a discussion, I respectfully disagree with you. :-)
Here's my take on it. First, some definitions.
A defect is something that has been found during the testing process (by QA analyst or others) and should prevent the Story/Task from being deployed.
A bug is something that has been found during the testing process but is not something that should prevent the Story/Task from being deployed. We will fix it later because it is minor. Or a bug is something that is found in the production system/app/software - either by a customer or we find it ourselves.
Either way, a bug is created and added to the backlog to be fixed later (or now).
So in my scenario, a Defect is a different animal than a Bug. And the defect is a sub-task to the original Story/Task it is associated with. And if you have your workflow set up so that you cannot move a Story/Task to Done if there are open Sub-tasks, then the Defect is preventing the Story/Task from being deployed. Just as intended.
A Bug sits at the same level as a Story/Task. And as such can be tracked and reported on, separately from Stories and Tasks and Defects.
Those are my two cents. :-)
Read the story
