×Hi team,
Getting below error while I am importing the issue from the CSV.
I have tried to map the user with E-mail Id, user Id and User name but it's always show below wrror.
Help me with your expert skill.
I am using the Free plan on cloud.
Hi @Hitesh Prajapati ,
As the error mentions, you'll need to add that user into your setup first.
Navigate to the Admin panel -> Users -> Invite Users that are missing, keep the send email option off, and revoke all Product permissions if not needed.
Do let us know how it goes.
Thanks for the response, Users are already created and I am using the same e-mail id in CSV as well as I am mapping in to wizard as well.
But the error is same. Help me with other guidance.
thanks for the update, can you perhaps share the column names that you're trying to import?
If you're confident of all the users existing then would recommend checking the below:
Hope this helps :-)
Hello @Jehan Bhathena ,
Thanks for the JIRA mentioning, I am facing the same issue mention in that JIRA MIG-358.
I am using the Assign and Reporter filed.
