User receives a 500 error when trying to convert and issue
Alex Storey September 18, 2023
Several of our users are trying to convert issues to a different issue type which we often do. However before completion of the process they receive a 500 error. It works fine for users with the same permissions and when I logged in as them (I'm the site admin). Anyone have any ideas?
Wouter van den Berg
Did you try the Permission Helper?
Go to the project where the actions are required. Select Project Settings > Permissions > Permission Helper. Select the user and a issue that should be converted (Move) and see what the output is.
HI, yes I checked there and they have the correct permissions. What does seem strange is it is only affecting our users that are based in India
Wouter van den Berg
Hi @Alex Storey
Then the problem isn't permissions but the view. If they aren't Administrators they should only have the Move option to change issue type. The Next button is grayed out which makes it look like it isn't possible. But they should click it anyways. Can they share a screenshot of all actions?
Have you tried moving the exact issue. There are no post functions required for the issue type at hand or the created issue type? No missing fields etc?
Let me know.
Alex Storey September 20, 2023 edited
Thanks for coming back to me, yes I have done it when logged in as them. It seems to be when they convert any issue. Attached are the steps/pages numbered in sequence.
In terms of whether there are any post actions the last step is always that on screen shot 4
1. Convert to issue.png 2. convert to bug.png 3. next.png 4. finish.png 5. 500 error.png
Wouter van den Berg
Found that more users are experiencing this issue. Some more information here:
https://community.atlassian.com/t5/Jira-Software-questions/Error-500-when-converting-subtask-to-issue/qaq-p/1278198
Not sure if this has been raised as a bug or things you might try which work differently for you. But since you can execute on this action on behalf of the user it seems a bug to me.
Thanks for this, what would be the process for raising this as a bug
Wouter van den Berg
To report a Bug, you can raise a support case with Atlassian Support. They will help you create a bug if needed and work out the details needed to create one. Those that are eligible will be added to the appropriate project of Atlassian.
Let me know if you are able to raise a support request and if not let me know.
PS: If you have worked out the support requests and that ends up being submitted as a bug it would be awesome to share that in the post I shared so others know it's been submitted: https://community.atlassian.com/t5/Jira-Software-questions/Error-500-when-converting-subtask-to-issue/qaq-p/1278198
Hope you get this problem fixed soon.
atlassian, state of product 2026 webinar, product team report, webinar, product management, ai productivity, agile practices, team alignment, product report, atlassian learning, product strategy, discovery to delivery, survey insights
Webinar: State of Product 2026
We asked real teams how they’re coping with an industry in flux. Join this webinar to hear the research –plus tips for leveling up your team’s work.
Register now
