Using Automation to delete a specific label
Kristin Palmer
I have an automation that will add a label in specific circumstances.
  • When <custom priority field> = P1, add a "critical" label
  • When <custom priority field> = P2, add an "important" label
My problem is in the scenario where the user is switching around values in this field. I would like the following behaviour:
  • When <custom priority field> transitions from P1 -> P2, remove the "critical" label, add an "important" label, preserve any other labels that might be in the field already
  • When <custom priority field> transitions from P2 -> P1, remove the "important" label, add a "critical" label, preserve any other labels that might be in the field already
I can see how to "reset" the labels field when the rule is triggered by setting it to blank, however I don't know how to preserve the other entries in the label field and only get rid of the now erroneous label.
Ste Wright
Hi @Kristin Palmer
This is possible to do, within your Action you need to:
  1. Select Edit Issue as the Action
  2. Choose the field to set as "Labels"
  3. Press the breadcrumbs (3-dots icon) next to the drop-down field under the field selected - and select "Add/remove values"
  4. Enter the values to add / values to remove into their respective boxes
  5. Press Save
For clarity, this is how I created the rule:
  1. Trigger: Either "Issue Updated" or "Field Value Changed = Field"
  2. Branch: For Current Issue
  3. Condition: If Field = P1
  4. Action: Edit Issue - Labels, add Critical, remove Important
  5. Branch: For Current Issue
  6. Condition: If Field = P2
  7. Action: Edit Issue - Labels, add Important, remove Critical
Tested using the "Priority" field in our instance and it worked in both directions :)
Ste
Curt Holley
It's a shame the Add/Remove values option isn't available on a custom field that is a group picker.
Like Ste Wright likes this
Ste Wright
Hi @Curt Holley
It might be possible using "More Options" - using JSON to add/remove options from the field :)
Ste
Like Curt Holley likes this
Curt Holley
I might need more JSON skills for that, but I like your thinking @Ste Wright
Thanks for the tip!
bilel_arfaoui March 6, 2023
it is possible via this JSON :
"fields": {
"labels": [
"{{customfield_yourcustomfieldid}}"
This should probably work.
Kristin Palmer
Fantastic, thanks Stephen - I tested this out and it worked. Screen shot for illustration purposes for people who come to search this post in the future. :-)
