Using JQL to filter
Vladimir Matveev
How to write a JQL filter that will select only those issues that (for example) on 02/25/2021 were transferred from the status "Working on it" to the status "Waiting for code review"?
Walter Buggenhout
April 21, 2021
Hi @Vladimir Matveev,
It might not be entirely correct, but it will be pretty close:
status was "Working on it" on 2021-02-05 AND status changed to "Waiting for code review" ON 2021-02-05
Walter Buggenhout
April 21, 2021
The above JQL may also return issues that changed to status Waiting for code review from another status, but were also in status Work in progress on the same day.
Vladimir Matveev
Unfortunately, such a JQL query throws an error...
But I was prompted for another solution that works:
status changed from "Working on it" to ("Waiting for code review") during ("2021-04-18", "2021-04-19")
Like # people like this
Walter Buggenhout
April 21, 2021
Yes it does, and is more precise too! Thx for sharing!
Yuliia_Borivets__SaaSJet_
For the next cases when you have issues with JQL, you can try Dynamic Filters: JQL Replacer add-on. It's developed by my team to simplify database searches. Visual composer helps to set queries. It's easy to choose dates there:
Hope you find this helpful.
