Using REST API, Importing robotframework test execution result (output.xml) is giving 404
Preetam Baraskar
April 25, 2020 edited
I am trying to import robotframework execution result to execution cycle in xray using REST API. Refering the following link
https://confluence.xpand-it.com/display/XRAYCLOUD/Import+Execution+Results+-+REST#ImportExecutionResultsREST-RobotFrameworkXMLresults
response = requests.post('https://<server>/api/v1/import/execution/robot?testExecKey=XX-15275',auth=('<user_name>','<key>'),data=xml,headers=headers)
The issue(testExecKey) menntioned is already existing in the environment.
headers = {'Content-Type':'text/xml'}
Getting 404
Tried following,
curl -H "Content-Type: text/xml" -X POST -H "<user_name>:<key>"  --data @"output.xml" https://<server>/api/v1/import/execution/robot?testExecKey=XX-15782
<!DOCTYPE html><html lang="en"><head><meta charset="utf-8"><meta http-equiv="X-UA-Compatible" content="IE=edge"><title>Oops, you&#39;ve found a dead link. - JIRA</title><link type='text/css' rel='stylesheet' href='/static-assets/metal-all.css' media='all'><script src='/static-assets/metal-all.js'></script><!--[if lt IE 9]><link type='text/css' rel='stylesheet' href='/static-assets/metal-all-ie.css' media='all'><script src='/static-assets/metal-all-ie.js'></script><![endif]--><!--[if IE 9]><link type='text/css' rel='stylesheet' href='/static-assets/metal-all-ie9.css' media='all'><![endif]--><meta name="decorator" content="none" /></head><body class=" error-page error404"><script type="text/javascript">document.body.className += " js-enabled";</script><div id="page"><header id="header" role="banner"></header><!-- #header --><section id="content" role="main"><div class="aui-page-panel"><div class="aui-page-panel-inner"><section class="aui-page-panel-content lowerContent"><div id="error-state"><span class="error-type"></span><h1>Oops, you&#39;ve found a dead link.</h1><ul><li>Go back to the <a href="javascript&colon;window.history.back()">previous page</a></li><li>Go to the <a href="/secure/MyJiraHome.jspa">Home Page</a></li></ul></div></section><!-- .aui-page-panel-content --></div><!-- .aui-page-panel-inner --></div><!-- .aui-page-panel --></section><!-- #content --><footer id="footer" role="contentinfo"><section class="footer-body">
<ul class="atlassian-footer">
    <li>
        Atlassian JIRA <a class="seo-link" href="https://www.atlassian.com/software/jira">Project Management Software</a>
        <span id="footer-build-information">(v1001.0.0-SNAPSHOT#100125-<span title='84eb0935209574a9983e2839ed793f423c8e12fe' data-commit-id='84eb0935209574a9983e2839ed793f423c8e12fe}'>sha1:84eb093</span>)</span>
    </li>
    <li>
        <a id="about-link" href="/secure/AboutPage.jspa">About JIRA</a>
    </li>
    <li>
                        <a id="footer-report-problem-link" href="/secure/ContactAdministrators!default.jspa">Report a problem</a>
    </li>
</ul>
Vedashree Paranjape July 17, 2024 edited
It seems the syntax of curl command in the documentation is incorrect. Following command worked (this is for Cloud, where you dont need to replace the domain url with your server url but keep it as it is as http://xray.cloud.getxray.app) :
curl --location 'http://xray.cloud.getxray.app/api/v1/import/execution/robot/multipart' \
--header 'Authorization: Bearer <enter token here>’ \
--form 'results=@"/Users/xyz/output.xml"' \
--form 'info=@"/Users/xyz/create_test_exec.json"'
    "fields": {
        "project": {
            "id": "10402"
        "summary": "Brand new Test execution",
        "issuetype": {
            "id": "10007"
    "xrayFields": {
        "testPlanKey": "DEMO-15"
Preetam Baraskar
May 28, 2020
I also tried with id instead of username but no luck.
Can anyone pls help
Prem Singh September 6, 2020
did you got the solution?
Kanupriya
March 4, 2024
any one got solution to this?
It seems the syntax of curl command in the documentation is incorrect. Following command worked:
    "fields": {
        "project": {
            "id": "10402"
        "issuetype": {
            "id": "10007"
    "xrayFields": {
Like • Siva Bathala likes this
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
